Status
Not open for further replies.
1 - 8 of 8 Posts
Im planing on running 4 wire 14 Ga. speaker wire in my walls to all my speakers. Im using the 4 wire tied together into 2 wire netting 11 Ga. wire runs. My question is not if 11 Ga. Wire OK or should I use some kind of plutonium plated supper wire.
Want I want to know is the effect of splitting the wire multiple times. Im going to be putting in a wall plate with binding posts for each set of speakers behind my receiver and a corresponding wall plate at each speaker. Witch means that I will be essentially splitting my wire 2 times and "splicing" it back together. What I mean is this I will have a short run of wire from my receiver to the wall plate, then a run of wire in the wall to the next plate and finally a short run of wire from the final plate to each individual speaker. All this means I?m now using 3 wires to make up a run I would typically use just 1 for if not for the fact Im hiding the wires.
Is there any negative effect running speaker wire this way? I know is done like this all the time I was just curious as to its effect.
Thank you
a friend of mine is doing this exact same thing with his setup. he's using a midlevel yamaha receiver with all polk speakers and we can notice no signal loss or sound quality loss so you should be ok.
Discussion Starter · #3 ·
Thanks for the reply JTUSA4. I know it’s done all the time. I was just curious as to its effect. With all the debate over wire Ga. And types I was thinking that the effect of essentially splicing together speaker wire would have a grater effect on performance on all but the longest of runs then would the type or Ga. Of the wire used.
I guess it’s a silly question, but I’m new to a lot of this and I thought would ask before I went ahead and put the wire in my walls to see if there was any effect and if so if there was a better solution..
So long as the connections at the wall plate are well made (both permanent in-wall, and binding post connections), there should be no significant deterioration of the signal. The short length of solid brass (or other material) will probably have a lower resistance than the cable itself over an equivalent length. The contact is the only thing to watch for... check/clean periodically to make sure there isn't oxidation (if you use bare wire), dirt/dust, looseness, etc.
Using both pairs in 14-4 cable works great for each run.
As long as you don't have poor mechanical connections or oxidation, the extra pieces of wire won't matter.
It doesn't matter.
Unless you are using state-of-the-art, million-dollar source equipment and power, you will not hear a difference.
schtien, here's what I suggest:
First of all, at the receiver, I hope you're not going to use separate plates for each speaker! Use a multi-gang plate instead.
Also, while you will be using the 4-conductor in the wall, there's no reason to use it between receiver and plate, or between plate and speaker. Just use a 14 or 12 ga. single pair.
The real purpose for using 4-conductor is 'future'proofing', i.e., in case you ever bi-wire or bi-amp. Otherwise, there's no advantage over a single, 12 ga. pair.
1 - 8 of 8 Posts
Status
