A/V cable suggestions
213 Views 2 Replies 3 Participants Last post by  migliore
I would like to upgrade my A/V cables. I currently use Monster Cable. Would someone please suggest a decent upgrade that I won't have to take a second mortgage to pay for. Thank you.
Status
Not open for further replies.
1 - 3 of 3 Posts
Check with your local A/V store. See if they'll let you try out cables. If they do, try some out. If you don't notice a difference, stick with the monsters and save the money for some DVD's (or something else). If you notice a difference go with the ones you like the best (and can afford). Be careful of the subliminal effects of having a bigger cable or wire or the thought that the more expensive sounds better.
But on the other hand if it makes you think it sounds/looks better, is that bad?
hastalavista!
See less See more
Check out synergistic research's Synergy or Alpha product lines.
Rob
Migliore Theater
1 - 3 of 3 Posts
Status
