I took care of video first, now it's time for the audio portion of the HT. I'm currently running the following inputs to my Mitsubishi RPTV:
1) HD cable box (Pioneer from TW) -- using component cables for the HD channels and S-Video for the non-HD stuff
2) Progressive-scan DVD using component cables
3) VCR
4) Output from Tivo (connected to a separate cable box) modulated and sent over a home video distribution network using RG-6 cable into the Ant input
I'm looking at receivers in the 300-500 range and I'd like to know the following:
1) Will the component video switching degrade my signal at this price level? I looked at the SONY STR-DE695 ($300) and it claims to switch at an 80mhz bandwidth. However, a Sony customer svc rep told me not to use it for HD cable signals and said to continue running the cable box directly into the TV
2) I don't see receivers with RF inputs. How do I connect my RG6 to the receiver? Are the cheap converters OK to use? If not, what would you recommend?
3) I presume that I'll still have to send multiple video outs to the TV (at least component, composite, and s-video). Because of the mix of video inputs (RF, s-video, composite, and component) what happens when all of these are connected at once? Does the receiver automatically sense the type of signal being played and use the proper output path automatically? Or do I have to manually tell it which output to use?
4) Should I continue to keep everything hooked up to the TV and just use the receiver for the audio portion of the signal? This seems like it would be a waste and would introduce much confusion when non-techies try to operate the systems.
3) VCR
