1 - 5 of 5 Posts
· Registered
Originally Posted by jiggamandan /forum/post/16864515
just hooked up my a2-300 to a denon1909 via rg56 coax and two rca tips. Im getting a hum and no real punch at all. Havent run audessey but it should hit after i set it up manually. What am i doin wrong?
You have whats called a ground loop. As far as no punch, make sure crossover on the sub all the way up (120) and you're volume knob at 12o"clock position and you're phase set to 0. Make sure you're speakers are set to small. Here is some info on ground loops. http://forum.blu-ray.com/showthread.php?t=97963
· Registered
Originally Posted by jiggamandan /forum/post/16864587
yeah i checked the ground loop issues already...dont think its that but ima try a 3 to 2 prong plug...Fixed hum bars on my samsung
I will bet you if you disconnect you're coax going to you're cable box input the hum will be gone.
1 - 5 of 5 Posts
