I don't know if this is a problem so to speak or if it is possibly an issue with my new receiver or the HDMI connection between the two but I thought I would check and see if anyone has noticed this while playing audio CD's on their A2.
The first part of the oddity is that when the audio CD is playing back, the timer on the front of the A2 doesn't track seconds accurately. It wil count 1,2,3,4,5 and then it will pause on 5 for a second and a half then jump quickly through 6 and then count okay for 7,8,9, then pause again and jump ahead again. It isn't literally on this particular timing schedule, but if you burn a CD and play it back you'll see what I mean.
The real potential concern is that I have gotten audio drop outs two days in a row now. Yesterday it was on track 3 of a CD. I got to the 1:18 mark and the audio dropped out for a half second. I skipped backward and it happened again at the exact same time. I turned the receiver's volume down while I repeated it a 3rd time and the problem went away. Curious to see if it was volume induced I turned it up higher than it was originally. The problem was still gone.
Since this was all done on a brand new Onkyo 804 I chalked it up to break-in. I doubt there is such a thing but I'll believe if it the problem never comes back. Today on the same CD but track #6 I had the same thing happen at the 29 second mark. I got it to repeat a couple of times and again changed the volume. Again the problem disappeared. So I turned the volume up and it re-appeared. So now I eject the CD and place it in my Sony carousel DVD player. I played both songs and never got the error at any volume. Also, I have played this disc before on the Sony and never had it skip/dropout. So I popped it back into the A2 and the problem refused to repeat. I decided one more back and forth switch and I would call it a night. The A2 wouldn't turn off. I had to hold the power button for 10 seconds as per the manual to get the machine to turn off. After ejecting the CD and playing it in the Sony again the problem still did not surface on that machine. I put the disc back in the A2 and the problem failed to repeat.
This is an iTunes burned CD played back optically on the Sony and HDMI on the A2. I may try the optical connection on the A2 tomorrow but if I can't get a repeat, that doesn't mean HDMI is at fault as this issue appears at random.
Has anyone else had this issue on the A2? I have yet to find a way to get it to repeat consistently so I can't say if it is more likely to happen when the machine is first turned on or after it has been running for an hour. I have never had a DVD playback issue and since I don't really intend to use this player for CD's, it is almost a moot point. But if this is a problem and other people experience it, I'll bring it to Toshiba's attention. Could it be the counter is indicative of the CD not reading properly and when it isn't buffered right I get the drop out? If that is the case I would think it should happen more frequently. I have not gotten this to occur on any other CD's and this one is still in near flawless shape. I think it is odd it happens in one spot one day and another spot the next. Also, it is definitley not a skip as when the half second of silence ends and the song plays again, it doesn't start from where it left off. That half second played back as if muted. Oh and lastly, I don't hear my 804 clicking like it is changing inputs or anything.
Sorry for such a long post but I want to be as clear as possible.
Greg
Greg
