I've been using a replay 2000 and motorola cable box with absolutely no problems for the past year. All of a sudden, when I type in say "123" on the replay, the box will read it as "111233" every time. If I just type in two numbers like "069", the cable box will shut off and back on. I use an IR blaster. The cable box will change channels just fine if I use the cable company's remote. Also, the channel display is permanently lit on the cable box. It used to go back to the time after changing channels. When I hit menu (on the cable box itself), it ignores that command. The only buttons that work on the box are the volume and channel. I know it's easy to jump and say it's the cable box, but why does the channel changing problem only exist when going thru the IR? Also, my replay froze for the first time tonight in about a year. Strange problem. Suggestions? I've already tried modifing max digits and stuff like that on the "zones" cable box menu. That's not the problem.
