Now Available: Tech Talk Podcast with Scott Wilkinson, Episode 19 Click here for details.
Originally Posted by aeblank /forum/post/18195908
Getting closer..
I measured my plug at 5.5mm and it is 24v and 2.5A.
Now I need the plug I.D. and the plug length.
Looking like $30-ish.
Originally Posted by aeblank /forum/post/18200080
First off, I take ZERO responsibility for anything that happens using either of these power supplies or any other power supply or any other product that exists that you might think about buying. You buy and use at your own risk.
I found 2 that I think would work.
Digikey PN T966-P5P-ND or a T1049-P5RP-ND
One has a right-angle connector, one doesn't. The OEM one is a straight connector, but I personally think a right-angle connector would work nicer. They have plenty of both in stock and they're both $32.90.
http://search.digikey.com/scripts/Dk...me=T966-P5P-ND
http://search.digikey.com/scripts/Dk...=T1049-P5RP-ND
Heck, you could buy you one, me one, and still come out ahead. =)
Let me know how it works.
