Status
Not open for further replies.
1 - 3 of 3 Posts
My accessDTV card was shipped on 4-4-03. As you know there appears to be a 'temporary' lapse of support. In the mean time I will ask any of you how to get the 'high definition' part of this tuner to work. I have Comcast as my cable provider. The card appears to work great on analog but I can't seem to get the digital to work. Any ideas? Thanks, Gene
genezalar,
I hate to tell you this, but it won't work. Comcast sends there HD over the cable using QAM which the AccessDTV doesn't support (and none of the other currently selling HD cards do either). Really the only way you can get HD with one of these cards is to use an antenna to get Over The Air stations.
-apnar
Discussion Starter · #3 ·
Thanks! I have an antenna so should I hit one of the antenna tunning forums to see if I have any luck getting it with this or some other antenna (coat hanger, etc.)? Gene
1 - 3 of 3 Posts
Status
