I just purchased an AccessDTV card (actually from another forum member). I will receive the card tomorrow. I had a couple of questions to try and avoid any of the setup problems I've read about in the numerous threads about this card. The connection questions are the ones I'm most concerned with.
First, and most important is a question about the connection possibilities of this card. I will never use this card to watch HDTV on my monitor. In fact, I'm moving away from even having a monitor. I run my HTPC into an NEC LT240K projector (Resolution of 1024x768). The NEC also has a VGA input that accepts component. For the sake of looks and simplicity, I'd prefer to have all of my video run through my AV Receiver, which has two component inputs and one component out (which I hope to run to the projector with the proper adapter). Knowing that, do you guys think I should just hook the AccessDTV card directly to the receiver with no loopback cable under the receiver's HDTV component input and have a seperate component input from my 9600xt to my receiver in the DVD input (this way uses the ATI vga/component adapter)? Or, should I connect the loopback cable and just have one connection from my HTPC from my 9600xt to my receiver with the ATI adapter (I wasn't sure if this would limit the viewing to 480p)? Or, if either of these ways is a bad idea, and you have another suggestion, that would be great.
Second, for sound, my receiver has ample digital coax and optical digital inputs. Should I connect the card directly to the receiver (I think this would be required if I connected the video directly to the receiver), or should I just use the onboard spdif out on my HTPC?
Third, which version of the software and driver should I install (is the least bug free with the most features) - the beta linked on this board or the ones on the website?
Fourth, I have a Hauppage PVRd-250MCE for recording SDTV. Can both cards be recording shows at the same time?
Sorry for the complete noob questions. I have read most of the AccessDTV threads (hence the decision to buy one), and I was having trouble extrapolating answers to these questions. Any help is greatly appreciated.
Wad
Wad
