1 - 7 of 7 Posts
Sure, it takes 5 digit codes, what are trying to program in? To enter code:
1. TV, STB, or AUX
2. press and hold SETUP for two blinks, release
3. enter 5 digit code
If you're reprogramming it for the AcessHd dtv converter:
1. STB
3. enter 0 2 1 8 5
Discussion Starter · #3 ·
hi,
what i want to do is use the remote with a different device.
i dont have the code to it.
can i manually search with this remote like you can with other universal remotes?
thank you
To do a codesearch:
1. tv, stb, aux
3. enter 9 9 1
4. enter 0- dtv, sat, or cable set-top-boxes
enter 1- tv's
enter 2- dvd's & vcr's
enter 3- audio devices
5. point the remote at the device, keep pressing and releasing CH UP key, if and when the device responds
6. press SETUP to lock in code
Sorry the only converter code this remote knows is the AccessHd code. but if yopu want to search:
1. press the stb device key
3. enter 9 9 1
4. enter 0
5. point the remote at the device, keep pressing and releasing CH UP key, if and when the converter responds
In step 5 each press of ch up key gives off different power command, once you device responds, you press setup to lock it in. Remember there are many sat and cable brands, many having more then one code, so you could be pressing the ch up key for along time.
1 - 7 of 7 Posts
