It is a scaler. If the input source resolution exceeds the projector's panel resolution, the AccuBlender "blends" the source lines to achieve this physical constraint. If the panel resolution exceeds the source resolution
and the AccuBlender is enable, it brings the resolution up to that of the panel's by adding and blending lines. If the panel and source resolutions are identical, it does nothing.
I have a VT540 and have been
very pleased with the scaling of HD sources. Wait, make that
extremely pleased. When driving the projector with my PC, I run at XGA resolution so there is no effect there. I am also very pleased with the Accublender results using one of my
composite satellite receivers as the source (especially from analog sources). Not HD good, but equaling that which I have seen from digital SD, and embarrassing the effort put forth by GI/Motorola's HDD200 (for NTSC conversions).
The button is labeled "Play", not "Pay". STOP the MPAA!
Our
Silent Angels
