Just set-up my new Acer RL70 with XBMC 12 (nightly build with new audio engine embedded) & I'm quite impressed for a $300 pre-built HTPC. I'm starting this thread here in the media streamers section as I feel this nettop may be a viable alternative to users with or considering Boxee Box, PCH, Dune, etc.
Even though the RL70 only comes with 2GB of memory, I'm having no issues streaming 1:1 BD rips in full 1080p and with both Dolby TrueHD and DTS-HD MA. Will be adding another 2GB to make the unit run a little snappier. What impressed me about the RL70 was how easy it was to set-up. Installed all Windows 7 updates, then installed the latest nightly build of XBMC. Added my movies share (SMB) and the gorgeous MQ3 skin. Went into XBMC setting and checked the Dolby TrueHD and DTS-HD 'capable' options, then tested a bunch of BD rips. Smooth video and hd audio playback! No tricky configuring, no worrying about codec packs to install, etc.
I had the Acer Revo 3600 in 2010, but ended up selling it due to its sub-par performance (at least for me). The RL70 blows it away however. There is a wireless keyboard and mouse included, and surprisingly even a WMC remote (similar to Boxee's, but nicer).
Teardown pics and some interesting discussion in this UK thread .
Also, using WMC for live OTA HDTV via networked HDHomeRun tuner. So, for the price, this appears to be a winner for what you get and can do with it.
Check out the Acer RL70 thread over at XBMC forum .
Update 8/19: HD audio also works via WMC (w/Shark codec packs) and via Boxee for Windows.
