1 - 2 of 2 Posts
I have a challenging project to create the best acoustical environment in a open floor plan SW Florida home. A rendering of the room is attached to illustrate the placement of equipment as well as the obstacles I need to overcome.
In short, the main equipment is as follows: BK Components Reference 70 processor, Sim Audio Titan Moon 5ch Amp, JVC RS2 projector (ceiling mounted), Revel Ultima Studio Front speakers, Revel center, Revel Sub.
Layout dictates that projector screen (electric drop down) is located on a corner, stone fireplace with front speakers flanking the screen. Very live - sound jumps off the stone. Center is below the screen. Sub is to the right of the RF speaker.
Floor is all travertine stone. Ceilings are 8' sheetrock. To make matters worse, room is open to 1) lanai, 2) dining room, 3) entry hall, 4) kitchen. The lanai does have a full wall of sliding glass doors that can be closed - but are normally left open. The dining room has three full height windows in front of the table.
I have corner bass traps available that I will most likely place behind the front speakers and the corner between the kitchen and dining room. I don't see a good way to stop the 1st level reflections in this room, which I'm guessing will arrive at completely different times because of the open wall to the lanai.
Not show in the drawing are the surround speakers that are on the wall where the kitchen begins. Any professional suggestions are much appreciated.
Jim
Originally Posted by zigzag666  /t/1522204/acoustic-design-suggestions-sought-for-very-difficult-room-sound-control#post_24472315
Jim
Probably not the best place to post this as this is the dedicated theater and construction thread. I would move this over to the speaker forum for better results.
1 - 2 of 2 Posts
