11201 - 11220 of 12743 Posts
I took a before and after waterfall graph and my DIY acoustic panels did a pretty good job taming frequencies above 100hz but below 100 is still a major issue. I want to do super chunk bass traps floor to ceiling up front but I am not 100% sure that is the best plan of action to target every thing below 100hz. I used roxul safe n sound for the existing panels. Should I continue to use the safe n sound? Should I use OC703? Should I use something else? Does anyone have any experience with super chunks that can point me in the right direction? I am worried that I will build these bass traps and not be happy with the results. Thanks in advance.
Safe N Sound is fine for super chunks. BTW you could use a bit more help below 100hz, but it is not looking as bad as you might think.
Thanks for the feedback. We make the panel with a wire that you put across the back (eyehook to eyehook) Basically hang it like a picture frame so you are not putting a lot of holes in your wall. It would not be a problem to send with french cleats but that is just a lot more holes you have to drill into the wall. If you would like for me to send you some just send me an email through my company website.
Bryan gave me the best advice on hanging these. Using the OOK type hooks like with picture frames. Instead of using the wire, I bought cheap small chain and s-hooks. I probably only spent $50 for chain, hangers and s-hooks for 7 panels. Makes it very easy to get them all level and they don't shift around unless bumped. I personally like the mounting method....Wire would have been a nightmare though.
So new REW measurement waterfalls after GIK treatment. They seemed to have helped out several db in the 30-40hz range.
LR Subs without Audyssey and without GIK
LR Subs Without Audyssey with GIK
LR Subs With Audyssey with GIK
I honestly didn't realize you were on at AVS! I don't visit this thread too often. I would prefer the french cleats because they offer a more secure, and stable hanging method. The extra holes in the wall don't bother me at all because I know the panel is secure. If I ever need to patch one hole, patching another next to it isn't that bothersome.
I do think it would be cool if you offered different hanging methods and it could be chosen prior to placing the order during the checkout process. Even as something as simple as the "eyehook to eyehook" or french cleats. While it might add a minuscule amount of overall cost, including mounting hardware is something I would recommend. Assuming I had no hardware at all, I would need to purchase mounting hardware anyway so if the panels went up a couple dollars each, it seriously wouldn't be a deal breaker.
Thanks for your time. I will try to get an email sent out today at some point with my forum name included.
EDIT: as someone else above mentioned (post 11205), the picture frame style (with wire) was a short nightmare. Especially to get the 3 panels even with each other.
Is Cotton Batting ear level and above still stand for the side walls if I am going OC703 Bass Trapping up to hear level?
Maybe I am misinterpreting BigMouthinDC in his post reply to me regarding the question, but has the general consensus changed to
"no cotton batting on the side walls anywhere" now. I thought it used to be that you wanted Cotton Batting on the side walls ear level to the ceiling to allow "diffusion" rather than absorption in combination with OC703 Bass Trapping floor to ear level.
I hung 6 panels on my back wall, it was a royal pain to get them all the same hieght. The wire way is very imprecise. My fingers were bleeding from undoing each one 5 times to get it even, then you bump it, or a guest does and they are uneven again. Would have preferred an extra hole in the wall per panel and French cleats. I may still take them all down and do French cleats. Hung 16 panels in total.
Man...You really need to go to Lowes. Don't use the wire.
Buy a little box of black chain. I think it's rated like 10lbs but that's consider torque etc. The panels hang straight down and even a Monster Bass trap is only like 15 lbs or something. So don't worry about the rating. The chain isn't going to break and it takes 2 big pairs of vice grips to even open a link.
A box of about 20 feet will cost around $10 and do about 5-6 panels. Buy some small s-hooks for about $0.25 each while you're there and a few packs of those angled hangers like OOK. My 7 panels are rock solid, perfectly level and took maybe 1 hour to hang 7 panels. They can tilt at an angle if bumped. If they do, just move left or right one link on the chain. I even have one hung on a door and when I shut the door, it stays straight.
I literally just put the same number of links on all 7 panels. Marked 6' up the wall where I wanted the panels. Hammered in 1 OOK hook and hung the panel. Everyone was straight and none needed redone. It's really that simple.
Sounds way better than what I did!
Front Wall acoustic treatment
What is the optimal way to treat the Front wall?
1" OC select sound black acoustic blanket (Link)
vs
2" OC 703
LCR speakers are towers behind AT screen (2ft) and not in-wall.
thoughts...
I have had customers cut the wire too two short pieces, attach to the eyehook, make a loop on the other end then hang that on a hook on the wall. I may give this some thought and come up with other options for customers though. The french cleat is great but it still will not be flush to the wall.
I used these Canvas Hangers to hang my DIY panels. If you have a small gap at the back to fit the hanger, the panel will fit flush to the wall. They worked very well. I shot a laser level across my room and got all the panels hung perfectly in one shot.
vs
2" OC 703
thoughts...
1" is never enough. Hence the 2", it wil deal with one lower octave. 4" is better!
  • Like
Reactions: nandkisham
For precision hanging there is a product called "loop line", it's knotted at precise intervals for even hanging and good for 25lb per each length (quit a bit more actually, I've hung about 50lb or more from a single length, I'd stick with the rating for overhead hanging though). I'm not sure how well it would work for this but I've used it for hanging a lot of different things (besides the posters it's marketed for hanging) and it works great, much easier than measuring and trying to guess.
http://clik-clik.com/loopline/, is one brand/maker, it's available at staging and event outfitters mail order, if you live or work in/near a big city there may be a handy place to pickup at a will call desk.
Cheers,
I was hoping to get some input on my room treatment progress. So far I've built corner absorbers for the front of the room. Unfortunately the back has a door and a counter, so I can't built a matching pair for rear room symmetry. It's my first audio system so learning all about speaker specs, then measurements and room treatment has been quite an exciting journey over the last few months.
The traps have a leg length of 23 inches, and a hypotenuse of about 32.5". I used R20 insulation. I saw something about R30 being ~5000 rayls, so I'm hoping R20 is in the range of 3000. I put a single layer clear garbage bag cover around the frame to contain the insulation and then covered in a pretty light fabric. I'm hoping they aren't thick enough to impede the effectiveness. Very unscientifically, I put the bag over my head with music playing and didn't notice any difference in sound.
I've attached a link to my REW file with all the measurements. They were taken in exactly the same position with an un-moved microphone. I'd appreciate any input on whether the changes I'm seeing are acceptable for absorbers this size. They seem to have made some difference in the waterfall decay down to about 60hz.
Also, any input on further treatments would be appreciated. My plan next is to build absorbers to treat the front wall first reflections and hopefully reduce SBIR. The center channel becomes a mess in the 200hz and lower region too.
I need to learn how to read/take ETC's and also see if I can troubleshoot the 70hz null issue on the left speaker. It exists pretty much anywhere I move the speaker, but isn't on the right speaker even though everything is set up exactly symmetrical. It is a basement room and the left wall is the edge of the house, so concrete backed I assume, whereas the right has another room adjacent. I'm thinking that could be the cause.
System is Polk LSiM 703/705/706c.
MDAT File:
REW MDAT File hosted on One Drive
Photo and single measurement should be attached to the post.
I am not the specialist, but I reckon you also would benefit not only from front wall treatment but also from side wall and ceiling treatments for first reflections.
Maybe you can make specific panel absorbers for the 70 Hz problem?
Have you tried swapping speakers?
Yes. And also the concrete floor is likely a huge issue. I'm aiming to do one area at a time so I can learn and improve my DIY skills as I go along. I have pretty much no experience with constructing stuff. The reason for doing front wall next is I have enough room depth to make the panels thick enough to absorb at least down to the transition frequency. The side wall will need to be thinner to avoid making the room width smaller than it already is. So ideally would use a more advanced technique.
Room is roughly 11'(w)*26'(l)*7.5'(h) so I'm already feeling the squeeze for width and height.
No they're about 80 pounds and unwieldy so it would be a pain to move them all the way around the desk. A sharp null didn't seem like a speaker issue to me. Especially when I have 1 or 2 measurements without it. I think when it was placed either directly against the walls in corner or far away from the sidewall. So it's likely a boundary interference issue, or desk. That issue is annoying but less important since I can cross over to subs above it which have flat response with no nulls.
But they stay put during LFE/ULF scenes of HT and music. Mine constantly shift to one side, then, due to physics, continue falling to one side. The far left panel fell against the ATS panel, so they didn't completely fall over.
ATS uses 4 total french cleats, but they are about half the size of the ones y'all stock up on (assuming they are the same as the ones I requested after having these issues). They also include a template and hardware for mounting. They are a millimeter or two from the wall at the most. They don't use slanted french cleats.
One of my wires broke today. About a quarter way from the left eye-hook if you're facing the back of the panel. Still can't figure out how - they're mounted using smooth nails
Interestingly, Dennis Erskine said (13 years ago in this thread) to cover the front wall with 1" InsulShield, and that 1" InsulShield is preferable over 2" treatment. Said the 2" is too absorptive. I am paraphrasing.
It's interesting how things have changed over the years. When building my first theater the advice was; 1" linacoustic on the front and sidewalls up to just above ear level, and poly batting on the rest of the walls above that.
Fast forward to today and most will recommend a minimum of 2" on the front wall and 4" plus on the rear wall, with 2" on the sidewalls from floor to ceiling with some diffusion and reflection points mixed in.
