Status
Not open for further replies.
1 - 2 of 2 Posts
Are there any DVI switches out there that automatically select the input by detecting a signal. Sure would be nice not to have to manually select the input.
Are there any switches with both DVI and component video inputs so it will convert the component video when that input is selected? (Would probably be a pretty expensive device).
All that I have read about have to be switched using a remote...if you have a programmable one it makes it easy except for the conflicts with codes which appears to be a problem with the Gefen.
No switchers have dual ports...all one or the other so far.
jack
1 - 2 of 2 Posts
Status
