Status
Not open for further replies.
1 - 12 of 12 Posts
I have the Toshiba 46H83 and because of the cost of the HDTiVo I went ahead and purchased a D* Tivo. No connected to my TV I have both the TiVo SD and Hughed HD TUner. Since the install (done by D* tech) I have lost PQ on my HD channels.
Does anyone else have dual tuners on their TVS's?? and if you do did you lose any PQ??
There's no reason adding a second input to your TV should impact your PQ on the HD box, did the tech change anything with the way your HD tuner was hooked up? Is it still outputting at the proper resolution?
Discussion Starter · #3 ·
I called Toshiba and they said that it could be the splitter that is compromising PQ. THe tech at Toshiba told me to disconnect the TiVo from the TV and see if that fixes the problem.
Are you losing PQ on the D* channels or OTA ones?
There should be no splitters on the sat feeds, you need 3 runs from your dish for everything to be connected correctly...
Discussion Starter · #5 ·
On the D* HD channels, very fuzzy, grainy
I'd double check all your connections, maybe he knocked something loose, I doubt your feed from the dish would cause that, low signal strength usually means no picture or heavily pixallated...
Discussion Starter · #7 ·
D* is coming out to recheck everything.......It took me a month to get the picture just perfect and one day for them to mess it up!
my bet is you are running the hdtivo through the center ant out on the tv (after splitter) i have the same tv
split the rf cable before the tv, and run half into tv and half into hdtivo (or 2 into hdtivo)
He doesn't have an HD Tivo and it's his D* HD channels, not the OTA channels that are a problem...
How do your SD channels look coming out of the Hughes HD box by the way?
Discussion Starter · #11 ·
I think they look really good......I mean not better than a regular tube BUT definitely better than my friends mits LCD and cousins plasma....
Discussion Starter · #12 ·
I dont have HDTivo....I have standard D* DVR and Hughes HD receiver both connected to my Tosh.
1 - 12 of 12 Posts
Status
