Originally Posted by
penngray /forum/post/18220660
No one else has asked why? so I will
Why are wanting to do this?
All content below your Center Speaker properly crossover point which is around 80Hz can just go through the main subs. Lower frequencies are not localized so its 100% okay to have them run through the regular sub out.
There will be zero advantage to you trying to run a full range CC. I believe actually a more inaccurate way since you probably want to stick the sub with the CC which could be a very bad place response wise in your room for the
No problem
Well..started with as just the subs for sub out, doubling them up made a huge difference in room response and slam. For two channel listening (like to do it with the front two speakers only), added a dedicated sub (initially connected through Proceed PRE, used HT bypass for movies) and made sound even better for movies too...palpable difference (I usually do blind testing with my friends since perhaps I want to listen to improvements
)...I really feel that the amount of info center has it may benefit substantially by a sub...and I can place it anywhere in room but prefer on front wall somehwere and it wont be under center channel!
