I ran my HDLEEZA into a JVC projector via DVI and a Samsung LCD via a DVI -> HDMI cable. Worked fine for me.
I also ran it at 1080P into the projector for a while, but then down rezzed to the native projector rate 1488x780 ? or something like that. Both work fine but I thought the native projector rate looked a little clearer.
If your looking to spend money then the HDLeeza is getting a little long in the tooth and I think my VantageHD does a much better job on SD sources, on HD I don't see a lot of difference. I project onto a 110" screen.
I now use the HDLeeza to the LCD and the Vantage to the projector.
