1 - 8 of 8 Posts
Hello -
I have a question about adding a sub to my to-be 5.1 setup.
Just purchased a set of energy rc-10s with the lc-cr center. The idea is to add energy rc-70s soon.
This all goes into a garage being converted to a man-cave. So large room with poor acoustics. It has had additional insulation etc
Use will be a mix of Ht and music.
I was going to buy a bic or klipsch sub to go with this setup but just saw a couple of svs systems go on sale.
My movie watching will not be at loud volumes to keep neighbors and sleeping kids happy. With that in mind two questions:
1. Does it make sense to plunk down an additional $400 for an svs given the low / medium volume of play?
2. If yes, is svs a good match with the energy fronts.
Subwoofers dont have to match speakers so any brand/model will do.
What do you mean an extra $400 for SVS? What subs are you looking at?
I wouldnt spend the extra money for the SVS and I wouldnt go with a sealed sub anyway. The Bic PL200 should do fine.
Originally Posted by Bond 007  /t/1518657/advice-for-adding-sub-to-energy-system#post_24378329
The pb12 is a better sub than the pl200. If you can easily afford it get that.
I agree. You'll get better SQ, and you don't have to run it loud just because it has the capability of getting loud.
1 - 8 of 8 Posts
