We are building a home and the basement is 15' x 22' and I want to install a home theater as well as leave some room for "game space" (board game table, foosball, something like that). So the entire room is not a dedicated theater space.
Since I'm building from scratch, and have about a 25-30k budget, I'd like to do Atmos / DTS-X. I would love advice on speaker placement and whether to do 5.1.2, 5.1.4 or 7.1.2/7.1.4 given the size and layout of the room.
Current equipment list I'm thinking about:
* Denon X7200 receiver (that would get me 5.1.4 or 7.1.2 without a second amp, could add 2nd amp if needed)
* Bowers-Wilkins CWM 7.3 for front L/R and center channel
* Bowers-Wilkins CWM 7.4 for in-wall rear
* Bowers-Wilkins CCM-682 (?) for ceiling speakers
* Sony HW40ES projector (I want to be able to play video games so the low latency is important.)
* Oppo BDP-103D
* Subwoofer (need to shop here). Will definitely wire for 2 subs, may start with one and add a second later.
* Xbox One with DirecTV Genie receiver via hdmi pass through
* Screen Innovations Black Diamond Zero Edge with LED screen (1.4 gain). Probably 115" diagonal, 16x9.
* Possibly a Control4 for simple control / Wife Acceptance Factor. Interested if the Denon remote apps on iPad are sufficient here.
Floor plan for basement is attached to the image. The bedroom next door will be my office/studio and I plan on having the wiring panel and equipment rack installed in the closet there to keep it out of view of the main room.
Given the desire to have the layout shared with a "game space", I'd like to have the projector on the wall facing the garage and the couch/primary viewing area be on the back wall of the room. I've measured the space and the screen and speakers will fit on that wall between the walkway to the bedroom and the closet.
Main concerns:
* couch will be against back wall -- i've heard lots of stories in avsforum about this being bad
* where to put the side surrounds since i don't have a wall on one of the sides (ceiling?)
* where to put the subwoofer(s)
I haven't measured the wall between the bonus/bedroom area which I could also use for the screen. given the room is 15' wide, it's probably 12' on that side and I could put couch/listening space to the left (facing right in the diagram, towards the bedroom). However, I don't want rear speakers and the projector all the way back across the room since I want that space to be available for foosball or a gaming table without all of the speakers/projector "invading" that space.
This house is currently a piece of dirt so I want to get it right when i go wire in cat6/speaker wiring to get an amazing home theater experience. thanks for your help!
* Oppo BDP-103D
Main concerns:
