Hi,
Wife and I are doing new construction of a custom plan (architect is mid-way through design). Gameroom and theater are on 2nd floor. There is a bathroom upstairs too, and some unfinished storage. Other than the gameroom/theater, there is no other living space upstairs.
We have to place the theater in the same general location as gameroom because that's the only place we have for it. After looking at some of the pictures of theaters in this forum, we may be on the light side in terms of budget. Below I ask about alternatives to soundproofing, lighting, etc.
(See attached zip of layout and 3D views. Pay no attention to the ceiling of gable roofs... CAD program had an issue)
1. Soundproofing:
1.1. 3 sides of gameroom/theater share a wall with the attic. These walls will be stuffed with fiberglass batting (R-13).
1.2. Floor of the attic area is also the ceiling of the 1st floor, but attic area floor will have R-30 insulation
1.3. Ceiling of gameroom/theater will have R-30 insulation
1.4. Standard insulation (R-13) in the wall that borders stairwell and bathroom
1.5. R13 batting between theater floor and 1st floor
Is this sufficient soundproofing? Probably not as good as soundproof panels, but certainly cheaper.
2. Lighting:
2.1. Separate lighting control above Pool Table
2.2. Cellular shades (blocks 100% of light) on 3 windows
2.3. Separate lighting circuit to control ambient light in theater area
If no one is playing pool while the projector is running, then lighting won't be a problem. My concern is for those times when pool players want to watch TV... I figured that having a directed light shine on to the table wouldnt interfere with the darkened area of the theater. Hence, TV viewing should not be a problem. Seem valid?
These two issues are my biggest concern. I have no desire to create an actual "theater" per se, but I do desire a theater-like environment.
I appreciate any and all feedback!
layout.zip 206.568359375k . file
1. Soundproofing:
2. Lighting:
