Status
Not open for further replies.
1 - 3 of 3 Posts
· Registered
I've narrowed my decision down to 3:
Mitsubishi LT3020 30"
JVC LT-26WX84 26"
Samsung LT-P266W 26" (not yet available?)
I'm working with a cabinet opening 30"W x 24"H.
Most of the 30" models won't fit. Speakers not necessary.
Open to more suggestions.
I've not seen any of the units in operation.
The LT3020 would fit but I would have to remove stand and rig into cabinet with a wall mount. I considered the NEC LCD3000 but from what I can tell the response time is not fast enough for home theater use.
· Registered
Discussion Starter · #3 ·
Thanks. I don't see any dimensions or response time in the specs.
Meanwhile I did go into Goodguys and saw the Mits and the JVC. The Mits looks great, and now they have 2 new models, the LT-3040 and LT-3050. The only difference between the LT-3020 and the new models is that the 3040 has an added white bezel and the 3050 a black bezel. The electronics, I was told, is the same.
1 - 3 of 3 Posts
Status
