Advice on a $400 CAD receiver.
341 Views 2 Replies 2 Participants Last post by  nrubenstein
Hello,
I am just looking for an A/V surround sound receiver. I spend a lot of money on computer stuff now, so I don't have a huge budget left for audio stuff. :(
So, with that out of the way, I have narrowed my choices down to two receivers that are both available for $400 CAD. One is the TEAC AG-D9320 and the other is the Pioneer VSX-810S.
The pluses and minuses of the TEAC are:
- higher current stereo output: 130x2 or 100x5...not sure if this means anything or not though
- seems this is "high current" amp whereas the Pioneer does not have that listed anywhere
- Onscreen display
- Excellent Costco return policy.
Pioneer:
- 6.1 channel support although I believe it is Matrix surround and not Discrete
- "better" brand name???
- one more video input, one more audio input
- learning remote
- lack of onscreen display
- I believe this is a "newer" model than the TEAC.
So, I guess what I am wondering is if anyone knows if the power amp in the TEAC is better or worse than the Pioneer. Also, is the 6.1 feature of the Pioneer that big of a deal? My room is about 20x15 feet.
I have both receivers at home now, but haven't had a chance to play with them yet. I wanted to get some "expert" advice so that I would have some more guidance as to what to look for, etc.
Any help or advice would be greatly appreciated.
See less See more
Status
Not open for further replies.
1 - 3 of 3 Posts
Hello,
I am looking at the specs again for these two receivers and noticed that the TEAC is spec'd as "high current" amplifier whereas the Pioneer is not. Can anyone tell me how I can verify this? I have both receivers at home now, so I can put them both through their paces.
Also, can anyone please tell me what this high current really is and where I will notice a practical advantage?
Raymond
High current means nothing.
My advice would be to hook them both up and pick the one that sounds better. There isn't much else that you can do.
1 - 3 of 3 Posts
Status
