1 - 4 of 4 Posts
· Registered
I recently purchased the 67" Samsung LED DLP RPTV. I have decided that it is too large for my space and I would like to replace it. 55-60" range is what I am looking for. Here is what I mainly use it for: Watching blu-ray movies and HDTV broadcasts, I also play games on it every now and then. I'm looking for better picture quality and viewing angle. From what I have been reading I am leaning toward plasmas. I want high detail smooth action when I'm watching movies, that is most important. Sorry if this seems a bit vague, but I would like any suggestions.
· Registered
You basically answered your own question.
If all those things are important to you then the only answer is plasma. LCD viewing angle is a true issue, and motion is often a problem too. Read the shoot out thread.
Don't know what your budget is, but Panny, Sammy, and the king Kuro all make good choices.
· Registered
I would not call this suggestion a replacement rather a standard of excellence.
Pioneeer KRP 600M or Panasonic and Samsung plasmas will save your eyes from damnation.
1 - 4 of 4 Posts
