Status
Not open for further replies.
1 - 3 of 3 Posts
Discussion Starter #1
i have done a search but honestly, i have a headache from staring at screen for so long, so i was looking for a quick answer.
i am looking for a switch, basically 3 in 1 out. i use component hookups for my dvd player, OTA box and moto box. honestly i dont care if its auto.
thnx for the help.
I have an Inday RBG-4X and it is the best unit. You can control it by remote control and the price is not bad at all ($168). You can get it at www.inday.com. When looking for a unit you are going to want to make it has at least 34-38Mhz of bandwidth. That is what is need for 1080i. The Inday unit has 230Mhz of bandwidth. Audio Authority makes a unit that is between $200 and $250. The Inday has better specs and can be controlled via remote.
1 - 3 of 3 Posts
Status
