Status
Not open for further replies.
1 - 2 of 2 Posts
Hi I'm new to this forum and to HTPC.
As decent scalers are way too expensive, I want to build a PC for the exclusive purpose of scaling DVD's to match my 1024x768 LCD projector using 'Dscaler'. I want to use my Toshiba SD900E (same as SD9200) as the source. Can anyone offer me advice on components or alternatives to Dscaler?
I'm no computer wiz, so please try to keep the advise simple.
Cheers
Kane D Williams
Kane ; the only analog source deinterlacing solutions on htpc is definitely Dscaler. Depiste being on the Dscaler boat myself, this is quite an objective statement. See the FAQ here http://www.dscaler.org/FAQ.htm
However, if you plan on using an htpc, may be you'll want to try dvd playback from a dvd-rom also. This probably looks better than an external dvd player+ Dscaler.
Anyway, as you'll be using an htpc, give it a try and figure this out by yourself.
1 - 2 of 2 Posts
Status
