Status
Not open for further replies.
1 - 5 of 5 Posts
My home has a peaked roof in front, which is covered with lightweight concrete tiles. The back roof is a flat roof covered with a typical torch-down membrane.
I'm trying to figure out the best way to mount a mast. I think the tile roof is out, leaving the flat roof. I'm not sure about mounting a tripod and penetrating the roof with lag screws and covering with pitch pads.
Would some kind of non-penetrating roof mount be a good idea? I'm not sure something like that would stand up to the winds with a big antenna on it, even supported with guy wires.
Any thoughts?
How high a mast are you talking about?
If it was 5 ft. or less, I might try just screwing a tripd mount to a whole piece of pressure-treated plywood, and wieghting the plywood down with concrete block.
Discussion Starter · #4 ·
I'm figuring on a 10ft mast, maybe taller, I need an antenna in the "blue" range, ie, a pretty good sized one.
My eaves are probably not an option for various reasons. Pretty much gonna need to be mountd on the flat roof section of my 1 story house. The peaked part is tile, so I'm not sure what can be done there without messing up the roof.
1 - 5 of 5 Posts
Status
