Hi, I'm new here and just recently came into the market for a new TV after the 15 year old RCA ProScans magic smoke escaped. I hear it's really expensive to put that stuff back in..
I hope I'm in the right sub forum..
Anyways, at this point I'm look for a 60 or a 65 set. From a technical standpoint 1080p is all I really care about. I'm stuck with the DLP/Plasma/LCD/LED dilemma. My biggest concern is reliability and ability to withstand a 4 year old and a 9 year old and their friends. The TV is on probably 8 hours a day even if it's not really being watched. Large part of that is PS3 gaming.
What I've found in my price range of just above $1000 are as follows:
1 - DLP: 65 Mitsubishi WD-65738. The cheapest option, and the largest. Thickness is not an issue. I am worried about the white dot problem I keep reading about though. Other than that, parts should be relatively cheap to replace should a bulb go out or whatever.
2 - Plasma: 60 LG 60pv450. I'm concerned that Plasmas have a glass screen and may not be able to handle an occasional ball flung into the screen or a HotWheel driven on it. Not that I'm ever OK with that happening, but you can't control other peoples kids sometimes. Also they are heavy and top-heavy. Wouldn't want that thing toppling over on anybody.
3 - LED: 60 Sharp Aquos LC-60LE633U. The most expensive option. Haven't done much research on this as I just came across it. Would prefer to avoid this as it is the most expensive one unless it's inherently more reliable/durable.
Thoughts? More particularly around reliability and durability. Image quality is secondary at this point, as they all will be considerably better than the 15 year old Std Def rear projection. Anything about these sets in particular I should know about?
