Status
Not open for further replies.
1 - 3 of 3 Posts
I hooked my PC up to my Z1 via VGA. Games looked really nice, but when I hooked my PC back up to my monitor the screen settings were all screwed up. Different resolutions and the task bars were switched all around...
What should I set my desktop and games to for use with the Z1?
Depending on your video card, you might be able to create various profiles that are set up for whatever display device you are using.
I have 3 profiles set up on my ATI 9800: one for 640x480 to a small NTSC monitor, one for widescreen games at 1024x576 and one for the full 1024x768 desktop. I can switch between them with hotkeys.
I am pretty sure nVidia cards can do something similar.
You might ask this on the Home Theater PC forum and get more responses.
HTH,
Gerald
Discussion Starter · #3 ·
Thanks for the response, Gerald.
(PS, though I am not a praying man, I still like your sig)
1 - 3 of 3 Posts
Status
