Hi all.
I've been searching through trying to locate this information and either my search technique is subpar, or i'm using the wrong terms.
We're going to build a wall in front of an existing external wall in order to mount a 50" monitor and recess a single soundbar that's roughly 42"x5"x6".
the wall is small, being 51"w x 105"h. we'll probably end up making it slim at 8-10" deep. the monitor will be mounted on the wall, and not recessed.
is there a prefab box we should be acquiring for the speaker, or will we end up fabricating our own?
if we end up fabricating, are there any tips in terms of lining the box?
We'd also like to have an acoustical screen masking the box, so that it's flush with recess, and seated entirely within the box (so there is no frame visible around the box). We'd also plan on painting the screen to minimize the appearance.
i'm at a loss for finding any information on materials, but again, i'm either not using the correct terms or need to broaden my search.
any suggestions or pointers to information would be greatly appreciated.
thanks.
-tom
thanks.
-tom
