Locate the deflection board. It's the big one on the top of the projector that is hinged at the front. Remove the screws and tilt the deflection board up and out of the way. There is a metal arm to hold the deflection board in place.
The system board is housed in a metal cage between the red and green tubes. Remove this cage and locate the system board. It's the one nearest the red tube and has a 4 position DIP switch and a NO pushbutton switch near the top of the board.
With the unit powered on, change DIP switch position 1 to OFF, then depress the NO pushbutton. Change DIP switch position 1 back to ON. Use a non-metallic tool.
Done.
The usual precautions regarding lethal voltages apply.
Done.
