Hi,
I'm new to the Home Automation forum, but not AVSForum. I spend most of my time in the HTPC Linux forum. I'm looking to get into home automation. I'm new to it - if you don't can't various timers, motion sensor lights, my EtherRain sprinkler controller, my Visonic PowerMax security system, Zoneminder video surveillance system, and various jobs I have my HTPCs and servers do at home. I'm looking do a few things to start and then be inspired and learn and expand over time. Some of the things I know I want to be able to do:
There are a lot of options out there. I've looked through this forum and other places and have settled on Z-wave because of it's pervasiveness, support, and # of sensors available. I am looking at 2 different approaches to getting started (controller approaches):
1. Get a veralite or Hometroller Zee. I'm not interested in controllers than can only be controlled from a smartphone or via a cloud service otherwise I'd probably be leaning towards SmartThings
2. Run an controller on one of my servers using the Aeon Z-stick or some equivalent. Been leaning towards trying out Homegenie.
I don't want to spend a ton of time in maintenance but I'm fine with investigating and exploring setup and taking time to learn how to use things (I don't have much free time in a day, but I'm not in a hurry so I'll take the time I need). I'm pretty technically inclined. But since I'm more experimenting a lower budget to entry would be good so that's why I look at option 2 (plus I'm used to running many things on my servers).
Any advice on choosing between to the two options or another option/controller I should consider? At this point I'm leaning towards trying out 2 to start with. If someone has experience with Homegenie or some other Linux compatible controller software I'd love to hear it.
Thanks for any help you can give.
- Report when garage doors are open at times they shouldn't be
- Sense when my wife arrives in the garage and flash a particular set of lights in the house (So I know to change the channel if I'm watching something I don't let my little ones watch).
- Control a door lock
- Cut power to a portable heater and measure it's power usage when it's on
- Cut power to a couple of other outlets
- Be able to remotely control some lights in the house
- Monitor temperature, smoke, carbon monoxide levels
- Totally optional, but integration with my irrigation system and security system would be nice.
