1 - 3 of 3 Posts
I need to get a very inexpensive receiver that will do the following.
Take inputs from a media streamer (HDMI), a Wii (component), cd changer (analog) and process all the audio in the receiver, and pass all the video to the LCD over a single HDMI.
Is this the HDMI pass through, HDMI repeating, HDMI upscaling or something else entirely?
Does Yamaha or Denon offer something rather inexpensive that will do this?
I dont need the new bluray decoding and it only needs to be 5.1
Thanks in advance.
first we need an set budget not just "very inexpensive"
but for what your looking for this denon is the probrally one of the cheapest routes you can go
avr-590
the other option and probrally best for you is buy used off of ebay, people have gotton amazing deals off of there
Quite a few receivers can convert from component video to HDMI. Some receivers have had problems doing it with the Wii though, for some reason. Just giving you a heads up.
The feature is often called HDMI Upconversion - that is to say, analog video is converted to HDMI.
1 - 3 of 3 Posts
