Status
Not open for further replies.
1 - 3 of 3 Posts
Has anybody used a DVI switch to switch between a HTPC and DVI DVD Player? If so, what have you used? I'm looking at a cheap $70 DVI KVM,
from linkskey.
what do you think?
Also, i am about to order the Ae500 from **********, being in the US, do i need to get the 100-250 Free volt version, or is the one they are offering ok?
i think i know what ******** means cause i got my PJ from there and it's the only place where i've seen that option. no, you don't need that free volt version, i'm guessing that's for europeans, japan and the US share the same (or allmost the same) volt spec, i have mine hooked up with no mods or anything like that, same goes for all my jap consoles that i've owned (my last one is my 4 year old PS2). and just so you feel better, those guys are reliable, i had no trouble at all even tough they are overseas and they don't take Credit cards.
Premium Member
Right, your volt specs are fine.
-MP
1 - 3 of 3 Posts
Status
