Status
Not open for further replies.
1 - 7 of 7 Posts
I was just using my nec 6pg tonight and it just shut off and not when i try to power it back on it just sits there. Im getting no error codes. When I press the power button the standby light goes to power/remote and then after a second or two goes back to standby.. What should I do? help help! i would greatly greatly appreciate any help u can supply.
Chris
Ahhh..... that could be the power supply, or any number of things. Open the cover and turn on the PJ. Are any of the 2 LED's lit on the Deflection board?
Marc
Discussion Starter · #3 ·
The red light flashes..i didnt notice a second one but i didnt look too hard.. ill check
Discussion Starter · #4 ·
ok both of them flash.. the one in the middle of the defleciton flashes way brighter than the other one but none the less they do flash..
Chris
Ok, as long as they only flash, that's good. None should stay on. That would be a scan fail. Pull and reseat the system boards. If nothing, pull the power connectors from the F-drive and C-drive boards. They are the plugs closest to the front of the projector. Try again, Post back
Marc
Discussion Starter · #6 ·
which ones are the system boards? the ones in the silver case or the ones under the fan?
Chris
Discussion Starter · #7 ·
ok jsut an update.. unhooked power from focus board.. still no power.
Chris
1 - 7 of 7 Posts
Status
