I'm trying to get the bugs out of my OTA system in time for the Superbowl next weekend. I have an Samsung SIR-T150 box with 1.8 firmware. Getting a lot of drop out and pixelation at times from 13.1. 6 bars on the strength meter but the cursor above on the strength meter shows signal strength near half. Very slow tuning on 13.1 as well. Every time it drops out the signal meter goes to zero.
7.1 also a bit slow but less so. The rest work perfectly. All seem to be showing similar signal strength. Most have 7 bars, 4.1, 7.1, and 13.1 have 6 with an occasional flicker to 7.
I'm located in the North Valley off Rio Grande, just south of Alameda. Perfect line of sight to the towers. Should be a great reception area.
I'm pretty sure I've got the antenna pointed straight at the towers. Should it be pointed differently for 7.1 or 13.1? Do I need to update the firmware in the box to eliminate these problems? Is is possible some how the signal is too strong? Should I aim to one side of the towers or the other?
Would appreciate any help some of you more experienced local guys could give me. My local Albuquerque phone number is 890-0310. Thanks.
Dan
Dan
