I have a 4600 and it has been working fine. Today I was setting up a RS232 connector to tell the projector to turn on/off remotely via my remote. During this period the projector acted wierd turning on/off a couple of times. When it turned back on the convergence was gone, all internal settings appreared to be gone.
Now, in attempting to reconverge, I have noticed that I cannot use most of the raster. The picture is way over to the left (ceiling mount). When I try to use phase to move it to the right, at max phase it is almost there, BUT, the picture wraps backaround way short of the right side of my screen. When I adjust the blanking the wrap around point does not change. This is almost 1.5 inches (approx) from the edge of tube!!.
How can I adjust the beam on the CRT to use the appropriate amount of tube? Can this wraparound point be moved? Is there some internal setting which tells the computer the SAFE limits so people do not use too much raster??
Please help.
Chris
Please help.
Chris
