1) The STB only needs a firewire output.
2) Yes, you are SOL without a firewire output.
3) Finding an STB with a firewire out would be your first option. Something like a used SIR-T165 off e-bay would do the trick without killing your wallet..
Another thing you want to look into is 5c protection just so you are familiar with it, it can limit what digital material you can record.
