1 - 4 of 4 Posts
Hello,
Looking for some expert Advice on a possible speaker configuration for my HT.
I currently have a 5.1 system running the following speakers on an Integra DTR-50.2 receiver:
B&W CWM800 - Front Mains (2-way in-wall speaker system)
Description: 2-way in-wall speaker system
Drive units: 1x ø25mm (1 in) aluminium dome tweeter
1x ø200mm (8 in) woven Kevlar® cone mid/bass
Frequency range: -6dB at 35Hz and 30kHz
Frequency response: 40Hz-20kHz ±3dB on reference axis
Sensitivity: 89dB spl (2.83V, 1m)
Crossover frequency: 3.5kHz
B&W LCR600-S3 - Center
Description: 2.5-way vented-box centre system
Nautilus tweeter
Kevlar® brand fibre cone
Drive units: 1x ø25mm (1 in) alloy dome high-frequency
2x ø165mm (6.5in) woven Kevlar®
cone bass/midrange
Frequency range(-6dB): -6dB at 48Hz and 42kHz
Frequency response: 60Hz - 22kHz ±3dB on reference axis
Crossover frequency: 300Hz, 4kHz
B&W CCM50: - Rear Surrounds (2-way in-ceiling speaker system)
Description: 2-way in-ceiling speaker system
Drive units: 1x ø25mm (1 in) Ultra-12 tweeter
1x ø130mm (5 in) woven Kevlar® cone mid/bass
Frequency range: -6dB at 50Hz and 22kHz
Frequency response: 55Hz-20kHz ±3dB on reference axis
Sensitivity: 88dB spl (2.83V, 1m)
Paradigm UltraCube 10 - Sub
Description: 10" Sub Woofer
Subwoofer Cut-Off Frequency: (continuously variable 40 Hz - 150 Hz)
Class D Power output: 1950 watts Dynamic Peak/650 watts RMS
I am considering moving it to a 7.1 system using some Boston Acoustic speakers I have had for many years. The BA's have been in storage now for about 5.5 years and I really cannot recall details on their sound in comparison to the B&W's - all I remember is at the time they seemed decent. My big question is - would mixing in the BA's with the B&W's be a bad idea? Would I end up with a decent sounding 7.1 HT system or would I be better off leaving the system as a 5.1 and keeping the BA's in storage?
Below are the specs on the BA speakers that could be added to the system:
Boston Acoustics Lynnfield VR960 - Possible Mains?
Frequency Response: (+/-3db) 29-20,000HZ
Sensitivity [1 watt (2.83V) @ 1] 90db
Built-in Subwoofer Amp: Power 75 watts RMS
Bass Unit: 8" (200mm)
Midrange: 4 1/2" (115mm)
Tweeter: 1" (25mm) anodized aluminum
Boston Acoustics VRS Micro Di-Pole - Possible 7.1 Rears?
Frequency Response: (±3dB) 120-20,000Hz
Sensitivity: [1 watt (2.83v) at 1m] 86dB
Full-Range Driver: 31⁄2" (89mm) copolymer
High-Frequency Driver: 21⁄2" (65mm) polymer-treated paper
Crossover Frequency: 350Hz
Any thoughts or advice on this setup from you AVS forum professionals would be greatly appreciated!
Don't mix the front left, right and center speakers - they need to be
voiced matched. You can use a different brand for surrounds. If you
do not have a Boston center - then use B&W for the fronts.
Don't be afraid to use anything g that sounds good to you. As long as the speakers and amp don't over/under power eachother, you should be good to go. The most important feature for any speaker is accuracy, but each person has their own taste as to the timber. Good luck!
1 - 4 of 4 Posts
