Status
Not open for further replies.
1 - 9 of 9 Posts
· Registered
Hi,
I have the Rotel RMB-1075, RSP1066 setup which I purchased in the U.S and now brought the setup back home to Cyprus where we use 230-240V electricity as opposed to the 110-115V used in the States.
Obviously I use a voltage converter in order to use the equipment but I was wondering if it would make a difference if the converter was of a greater VA (I am currently using a 1000VA unit which converts the 110V to 240V) and if it is important to hook up a UPS system and/or a power conditioner/stabilizer. The power amp uses 120V, at 800WATTS power consumption and the Processor uses 120V, at 40WATTS consumption.
Any input would be great. Thanks.
· Registered
The power rating is maximum-capacity. It doesn't 'force' electricity into the load. The greater the headroom, the cooler the transformer runs.
· Registered
Which converter are you using? Does it do both frequency (50 vs 60 Hz) and voltage conversion?
· Registered
I would try to have it converted so that it could be plugged into the wall. At worse a pair of wires needs to be moved on the power transformer. At best there is an internal switch.
· Registered
Discussion Starter · #5 ·
Thanks for the input guys,
M NEWMAN : The transformer writes " 1000VA 110/240V 50/60Hz"
Swampfox : I am guessing that I would get an electrician to do that for me, right?
· Registered
Discussion Starter · #6 ·
Swampfox : I am guessing that I would ger an electrician to do that for me, right?
· Registered
According to the WEB site the units are easily converted from USA to Europe. Look in the Rotel manual or WEB site for a service center.
· Registered
Mitch, you must get those hiccups checked! :D
· Registered
Hi,
MitchD, Kypraios?
1 - 9 of 9 Posts
Status
