Status
Not open for further replies.
1 - 5 of 5 Posts
what is a good amp to add to a avr 8000 or onkyo 898 or even a pioneer 45,47. i need a receiver and put an amp with it but what amp would you suggest..
Discussion Starter · #3 ·
room is 18x28.....rockets..750/200/300/300...i don't want to spend a lot on a mega receiver so i thought an amp added to a lower priced receiver would be better than a mega receiver....am i correct in this thinking. if so what amp would you suggest. something to run my fronts or backs?
I wouldn't recommend a receiver only for the pre outs. You'll end up with a bunch of amps you paid for and are not using. Many will use their existing receiver for a pre-pro if the amp is an after-thought, but as a rule don't purchase a receiver for that purpose. The receivers you mentioned aren't cheap and you should be able to find a nice dedicated pre-pro either new or used for the same cost.
That's some good advice. For that kind of money why don't you just get a pre-amp like the B&K or Anthem. There are a ton of good moderately priced pre-amps.
1 - 5 of 5 Posts
Status
