1 - 2 of 2 Posts
Im going to build these:
http://www.parts-express.com/dayton-audio-18-reference-series-ho-subwoofer-and-cabinet-package--300-7094
I already got the drivers, and along with them, I got this amplifier:
http://digisynthetic.en.hisupplier.com/product-859898-SPD2000S.html
Product Detail
Place of Origin: Guangdong, China (Mainland)
1.93% efficiency, classD amplifiers
2.High-cut and phase reversal control
3.Damping factor:>1500
4.24 bi DSP,24 bit ∑AD/DA,48KHz sampling rate
5.3-band PEQ and Limiter, parameters adjustable via PC
6.Crossover type and slope: butterworth, Bessel and Linkwitz-Riley
7.High-cut frequency range:50Hz-250Hz
8.Frequency response:20Hz-250Hz
9.Size:226mm*238mm
2000W/4Ω
Im very skeptical regarding these "no name amplifiers" - but perhaps someone has some knowledge about them, or can tell me if this amplifier will be any good for my 2 sealed Daytons ? 1000watt on each Dayton seems about right. I just can't find much information about it.
I can also use a Behringer Ep2500 (2x600watt.. 600 on each woofer) & a DCX 2496.
Which one should I use to get the most out of them ?
not familiar with that amp.
why not grab an inuke with dsp. super cheap power. you could get a 6000dsp (or a pair of 3000dsp's) and run the limiter to keep power to about 1100 watts.
1 - 2 of 2 Posts
