1 - 2 of 2 Posts
Discussion Starter #1
I want to have surround in my living room, I have rear speakers in the ceiling, and 2 LR under TV in furniture.
But at the same time, I would also like the amp to be able to source 2 ceiling speakers in kitchen/dinning room with different source at the same time - is this possible?
The amp has to fit my furniture, which means it can have a depth of 36.5 cm (14.3") with cables plugged in - is this at all possible?
I am on a budget, and is also open to used hardware.
What should I look for, and how do I determine need Watts?
Thanks in advance.
1. It is possible.
2. You need to find out the sensitivity and power limits of the speakers to determine exactly how much amp power is demanded.  Not critical, though.
3. I have no idea about dimensions but you neglected to state, in numbers, what your budget range is.
1 - 2 of 2 Posts
