Status
Not open for further replies.
1 - 5 of 5 Posts
I have a bad blue CRT in a Ampro 3600. Im not all that familiar with Ampro and less familiar with the brand name Thomson which supplies the tubes for this model of Ampro.
I am hoping that there is a more popular name brand I can replace this CRT with.
Can anyone shed some light on this?
J Green
Thompson makes the magnetics, not the tubes.
You will find the manufacture of the tube on the side of the tube bell. You may have to pull the tube and remove the aluminum shroud to be able to see the info.
More than likely the tubes are Panasonic (MEC) and can be rebuilt by VDC
I believe they are 180dvb22 or 180dmb22 both economically rebuildable.
troy
Don't forget elitevideo ( www.elitevision.com ) makes the 3600. They should be able to solve this problem, or any other.
Chris.
1 - 5 of 5 Posts
Status
