Yes, Yes, Yes!!!
But really they are orphens unless you can order parts(over seas) or get them from us. The lamps are a little high in price but easy to find.
This unit is bar none best one to use if you have the extra room you need to keep it in while you shoot the image through the wall into your HT and on to your screen.
But to be real you other PJ will work just fine and you won't need a extra room.
See Ya,
C
