1 - 5 of 5 Posts
just curious if anyone else has had problems with big theater amps popping arc faults when turning on. my amps dont pop a regular breaker just an arc fault , my theater is in a bedroom and by code it is suposed to have an arc fault on it ,, any way just seening if any one else has had similar problems .
thanks for any reply
Yes, I have read that on other forums and newsgroups.
Arc-faults are far from perfect.
(what brands of amps?)
Discussion Starter · #5 ·
well I had a seperate 20 amp circuit put into the closet where all the equipment is , so yes its a dedicated home theater but its a bedroom in that it still has a closet , the bedroom outlets them self are still arc faults as well ,,
I guess what im trying to here from someone is that YES amps of this size and arc faults dont get along ,, and why its popping it , its it enough of a dead short when it fires with all the amper load that it trips it, ? thanks guys
1 - 5 of 5 Posts
