1 - 5 of 5 Posts
Anyone out there have any input on 5 to 7 channel amps with individual volume or input control for the different channels? The speakers I am bi-amping require it. I am looking at some B&Ks (7260 and 200.7) and some Parasounds HCA 2205 but am open to suggestions. I need something that will comfortably drive 2- 4 ohm loads and need 200wpc +.
thanks for the feedback.
Check out pro amps as they invariably have attentuators.
Carver multichannel amps also do, as do some Rotels and Adcoms.
Can't you accomplish the same thing by turning down (decreasing) the individual channel levels in the pre amp you are running? You can usually go up or down 10-12 dB.
1 - 5 of 5 Posts
