Analog cable on Syntax 27"
295 Views 1 Reply 2 Participants Last post by  jakub808
I'm sure the question has been asked, but I couldn't find anything in a search. My primary use for this would be SD television. Anyone with this unit have a comment on how it will look?
Status
Not open for further replies.
1 - 2 of 2 Posts
I have the 27" syntax, the SD cable looks pretty bad.. Well when you set the display to 4:3 and have the two black bars on the sides, it actually doesn't look terrible, but its about standard for LCDs mean, its not great by all means. But when you set it to full screen stretch mode, its a lot worst than my old TV.
Needless to say I ended up getting HD cable pretty much right after I got the set, once you watch a few hours of HD programing, even if its 4:3 and you are using the zoomed function, you do NOT want to go back to watching the regular channels. Syntax does look great with HD, DVD, and Computer input...
But heck for 1 grand, it kicks any ED Plasmas ass.
1 - 2 of 2 Posts
Status
