Status
Not open for further replies.
1 - 4 of 4 Posts
Just bought a plasma TV that supports only digital signals (and a couple of analog signals). Until my digital cable signal get installed in my house, I wanted to know if I could get a converter that will take my regular cable signal and out put a RGB set of signals into the TV. Essentially take in Coax and out put digital.
thanks
Most of the solutions you will find are NTSC to VGA converters. If your display has a VGA (RGB) input, this could be a solution. The boxes are very pricey for what you get.
An alternative would be to buy a TIVO unit. These have RF inputs and component video outputs. You will still be able to use the box, even after you get digital cable. It would require that you buy one of the units with a DVD burner. The straight recorders only have s-video as the highest quality output.
1 - 4 of 4 Posts
Status
