1 - 10 of 10 Posts
Current I have ANT806, Mounted outdoor vertically on the North-East corner of the house to pick up major channels (RF-7, RF-10, RF-12, RF-13...), but signals are not stable.
Here is my TV Fool result
hxxp:// www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d23c50684a0d517
I am thinking about MS-2000.
Based on this, which antenna would you recommend?
Thanks a lot for any help!
With signals that strong, an amp often makes reception worse. Get a real, conventional metal antenna, not a gimmick made of plastic. And no amp.
This small winegard should work well in your situation:
http://www.solidsignal.com/prod_disp...p?prod=HD7694P
Aim it ~175° (almost due south)
The only iffy channel may be RF10, but it will likely pick it up off the back side.
Aim it like this:
If you still have trouble with the VHF channels, add an FM trap to reduce FM radio interference to channels 7-13.
http://www.mcmelectronics.com/produc...LAID=220403171
Discussion Starter · #4 ·
I only have this mounted on the side-wall, on the east and north corner of my house. I can not have this in front of my house (West) as restriction.
I did try to put this on the roof, EW and NS pointing, only pick up some channels. ANT806 is very directional. I can not have it picked up signals from both directions. Specially for RF-13, it has to be East-West pointing if it is horizontally.
Discussion Starter · #5 ·
hxxp:// www.solidsignal.com/prod_display.asp?prod=HD7694P
Aim it like this:
hxxp:// [URL='http://i25.tinypic.com/3481svp.jpg%5B/img']i25.tinypic.com/3481svp.jpg[/img[/URL] ]
hxxp:// [URL='http://www.mcmelectronics.com/product/33-341&CAWELAID=220403171']www.mcmelectronics.com/product/33-341&CAWELAID=220403171[/URL]
[/QUOTE]
Is this VHF only? We have UHF channels as well.
I am having issue of picking up VHF.
The Winegard HD7694P has great gain for all the VHF & UHF channels being used in your area.
The MS-2000 typically receives TV signals "equally poorly in all directions."
Typically, the best performing outdoor antennas are those that have no big pieces of plastic on them and are of tried & true conventional designs. Gimmicky or non-traditionally looking antennas are made & sold because people want and will often buy something that doesn't look like an antenna, not because of the way it works. In some cases they work fine, but in many cases, a coat hanger will also work fine, too.
Banned
If I lived in your house I'd buy two antennas.
The first one would be the HD7694P that has already been mentioned. You could also substitute the HBU-22. Aim it at 168 degrees
For CBS I'd add a Y5-7-13 aimed at 274 plus a channel 10 Jointenna.
http://www.solidsignal.com/prod_disp...p?PROD=Y5-7-13
http://www.amazon.com/Channel-Master...1148688&sr=8-3
If it's your house, HOAs cannot restrict antenna placement, if the restriction limits reception of the channels you want.
1 - 10 of 10 Posts
